New Arrivals!
New Arrivals!
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 2:37 pm
Iata cateva noutati si la categoria de lumini.
Zeedoshop.ro ofera discount pentru membri forumului!
zeedoshop.ro
UNREAD_POSTde misu_misu66 » Mie Sep 09, 2009 2:38 pm
Unde? :D
misu_misu66
Localitate: Glalati
Fusion FX Bar 1 ADJ
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 2:46 pm
Two effects in one chassis. RBG chasing led pixel blocks and a white LED sound active moonflower that rotates clockwise and counter clockwise to the music. Both effects are LED based. Great for house parties and mobile DJ's . 3 operating modes; Linkable master slave via XLR or DMX cable. Can be run using the UC3 remote or DMX 512 control functions turn on/off specific effects. Stand alone operation sound active.
SPECIFICATIONS
- Unique and compact lighting fixture - Member of the ADJ Fusion Series
- Includes 2 FX in one light: Red, Green & Blue LED Wash + White LED Moonflower
- LED Wash includes 108 LEDs (36 red, 36 green, 36 blue)
- Moonflower include one bright 3W white LED
- DMX-512 protocol
- Operational modes: Sound active, DMX, Master/Slave
- Includes mounting bracket
- Run all night - no duty cycle
- Long life LEDs (50,000 hr. rating)
- Compatible with the UC3 easy-to-use controller (sold separately)
- Multi-voltage operation: AC 100V-240V 50/60Hz
- In/Out IEC power connections to daisy-chain power
- Dimensions (LxWxH): 538x143x263 mm
- Weight: 3,7 kg
167 Eur / www.zeedoshop.ro
http://www.youtube.com/watch?v=6DYbDERWEck
zeedoshop.ro
Fusion FX Bar 3 ADJ
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 2:49 pm
White light effect. Unit features 3 strobing (variable speed) chasing or steady burn white LED pixel pods and 4 LED pinspot type effects (which also strobe, chase or steady burn) in one chassis. Very unique effect ultra bright and when strobing the use of the led pinspots give the depth and deep impact accentuating the led pixels wider angle strobe. Great for house parties, nightclubs, lounges, bands and mobile DJ's. Three operating modes. Linkable master slave via XLR or DMX cable. Can be run using the UC3 remote or DMX 512 control functions turn on/off specific effects. Stand alone operation sound active.
SPECIFICATIONS
- Unique and compact lighting fixture – Member of the ADJ Fusion Series
- Includes 3 FX in one light: bright white LED Wash/Strobe effect + 4x hard beam white Pinspots
- LED Wash/Strobe includes 135 white LEDs
- Each Pinspot includes one bright white 3W LED
- DMX-512 protocol
- Run all night – no duty cycle
- Weight: 3,7 kg
220 Eur / www.zeedoshop.ro
http://www.youtube.com/watch?v=-_vxqTZ-m9U
zeedoshop.ro
Fusion FX Bar 2 ADJ
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 2:52 pm
Three effects in one chassis. Two LED moonflower effects, 1 Mini Mega Pixel effect (RGB led pixels that chase different patterns). All effects are LED based. Great for house parties, nightclubs, lounges and Mobile DJ's. Three operating modes. Linkable master slave via XLR or DMX cable. Can be run using the UC3 remote or DMX 512 control functions turn on/off specific effects. Stand alone operation sound active.
SPECIFICATIONS
- Includes 3 FX in one light: Red, Green & Blue LED Wash + 1x Colored LED Moonflower & 1x White LED Moonflower
- LED Wash includes 144 LEDs (48 red, 48 green, 48 blue)
- Each Moonflower includes one bright 3W LED with 1x color dichroic mirror & 1x white mirror
- DMX-512 protocol
- Weight: 3,7 kg
205 Eur / www.zeedoshop.ro
http://www.youtube.com/watch?v=sOk8YVSXB8M
zeedoshop.ro
Fusion FX Bar 4 ADJ
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 2:54 pm
Three effects in one chassis. Effect 1 is a green 4.9mw laser that projects geometrical patterns. Effect 2 an LED based Tri colored moonflower that operates sound actively. Effect 3 a white LED variable speed strobe light. Great for house parties, nightclubs, lounges, bands and mobile DJ's. Three operating modes. Linkable master slave via XLR or DMX cable. Can be run using the UC3 remote or DMX 512 control functions turn on/off specific effects. Stand alone operation sound active.
SPECIFICATIONS
- Includes 3 FX in one light: bright white LED Wash/Strobe effect + TRI Color LED Moonflower + green laser effect
- LED Wash/Strobe includes 90 white LEDs
- Laser diode: green 4.9mW
- DMX-512 protocol
- Weight: 3,7 kg
285 Eur / www.zeedoshop.ro
http://www.youtube.com/watch?v=KFhR54SbyQc
zeedoshop.ro
Mini TRI Ball ADJ
UNREAD_POSTde zeedoshop.ro » Mie Sep 09, 2009 3:25 pm
The American DJ Mini TRI Ball is an easy-to-use rotating mirroball effect that produces 56 sound to light controlled beams.
SPECIFICATIONS
- Easy-to-use mini rotating ball produces 56 sound activated beams that change color and strobe to the sound of music
- 2x 3-watt 3-in-1 RGB "TRI Color" LEDs produces a variety of color effects (Red, Green, Blue, Purple, Yellow, Cyan & White)
- 3-position FX switch: constant rotation, no rotation or sound active rotation
- Light weight and very mobile
- Power consumption: 13W per unit
- Long life LEDs (100,000 hr. rating)
- Beam angle: 180 degrees
- Ball rotation: 15 RPM
- Dimensions (LxWxH): 195x195x152mm
- Weight: 1,6 kg
http://www.youtube.com/watch?v=Uo6s-2eiKwc
59 Eur / www.zeedoshop.ro
zeedoshop.ro
LED Trusslight 24VDC 18x1W / Eurolite
UNREAD_POSTde zeedoshop.ro » Joi Sep 10, 2009 5:15 pm
Versatile LED Trusslight * Ultra compact and bright, making it perfect for truss installation * Equipped with 18 x 1 W LEDs: 6 x red, 6 x green, 6 x blue * Controlable via optional EUROLITE LED PSU-24V DC controller * 4 EUROLITE LED Trusslight 24V DC 18x1W can be used with one controller * Ideal for booth construction, stages and any kind of truss * Advantages of LED-technology: extremely long life of the LEDs, low power consumption, minimal heat emission, defacto maintenance free with brilliant light radiation
Specificatii tehnice
Power supply: 24 V DC Power consumption: 23 W Number of LEDs: 18 x 1 W (6 red, 6 green, 6 blue) Dimensions (LxWxH): 140 x 110 x 42 mm Weight: 0.4 kg
ImagineImagine
ImagineImagine
222 Eur / www.zeedoshop.ro
zeedoshop.ro
Revo 4 ADJ
UNREAD_POSTde zeedoshop.ro » Joi Sep 10, 2009 5:32 pm
Specifications:
- LED DMX-512 Moonflower from the popular REVO Series with 256 razor sharp Red, Green, Blue & White Beams
- Produces unique and exciting LED patterns that may be projected on a wall, ceiling or dance floor – great with or without fog
- 256 total 5mm LEDs : 64 Red, 64 Green, 64 blue and 64 White
- 2 DMX Channel Modes (4 Channel mode or 256 Channel mode)
- 4-Button LED DMX Display
- Linkable via XLR connections
- Wide beam spread covers a large area
- 3 operation modes: DMX, Sound Active & Master/Slave
- Sound active from built-in programs
- Strobe function
- Beam angle: 50 degrees
- Runs extremely cool! - NO Duty Cycles! – Run all night!
- Includes hanging bracket
- Power Consumption: 29W maximum
- Extreme long lifetime of the LEDs (100,000 hr. rating)
- 1/4” input for optional American DJ UC3 remote control (sold separately)
- Multi-voltage Operation: AC 100-240V, 50/60Hz
- Dimensions (LxWxH): 312x306x334 mm
- Weight: 4.2 kg
http://www.youtube.com/watch?v=Skp7pu__RrY
265 Eur / www.zeedoshop.ro
zeedoshop.ro
UNREAD_POSTde scarface » Joi Sep 10, 2009 6:05 pm
http://www.youtube.com/watch?v=-_vxqTZ-m9U Asta imi place si in viitorul apropiat voi achizitiona o bucata. In cazul in care nu mi se pune pata pe altceva :lol:
UNREAD_POSTde zeedoshop.ro » Joi Sep 10, 2009 7:29 pm
cu una nu prea ai ce face.
Efectele iti ies cu 2 minim.
Sunt foarte capabile Fx bar-urile de la ADJ. chiar toate.
dar eu zic ca pentru efect deosebit tre sa ai in pachet minim 2.
zeedoshop.ro
UNREAD_POSTde scarface » Joi Sep 10, 2009 11:21 pm
Mai vedem. Acum se termina sezonul. Nu are rost sa investesc in ele si sa le tin la rece :lol: .... Si pana cand o sa le iau, poate ma razgandesc :D
UNREAD_POSTde lush » Vin Sep 11, 2009 8:58 am
Ceva mai ieftin asa ca pentru punatori de muzica ne trebuie.CEva bun si ieftin?
UNREAD_POSTde zeedoshop.ro » Vin Sep 11, 2009 9:36 am
in momentul in care voi lansa site-ul si shopul online... o sa aveti de unde alege. :)
Va las voua placerea de a cauta. :))
mai dureaza putin...
zeedoshop.ro
