Controller MIDI Pioneer DDJ-SZ
UNREAD_POSTde djcristian » Lun Ian 27, 2014 3:31 pm
Ultimul model de controller MIDI marca Pioneer. Modelul DDJ-SZ este cu adevarat inovator si high class din toate punctele de vedere. Un monstru MIDI fara nici o urma de indoiala.
http://www.youtube.com/watch?v=xeNdR_V_VMA
Info :
http://www.pioneerelectronics.com/PUSA/ ... ers/DDJ-SZ
MAIN SPECIFICATIONS
Software Serato® DJ
Number of Channels 4 audio channels, 2 mic channels
Input Ports CD/LINE x 4 (RCA), PHONO x 2 (RCA), MIC x 2 (XLR & 1/4 inch combined PHONE x 1, 1/4 inch PHONE x 1)
Output Ports MASTER OUT x 2 (RCA x 1, XLR x 1), BOOTH OUT x 1 (1/4 inch PHONE), HEADPHONE MONITOR OUT x 2 (front panel 1/4 inch PHONE, 3.5mm MiniPin)
Other Ports USB B port x 2
Sampling Rate 44.1 kHz
D/A and A/D Converter
24 bits
Frequency Response 20 Hz ~ 20 kHz
Total Harmonic Distortion Ratio Max. 0.002%
S/N Ratio 111 dB or above (USB)
Head Room 19 dB
External Dimensions 34.3” (W) x 16.5” (D) x 3.9” (H)
Unit Weight 22.9 lbs
SERATO DJ SYSTEM REQUIREMENTS
Mac Mac OS X v10.9/10.8/10.7/10.6
32-bit: (CPU) 2.0 GHz Core 2 Duo / (Memory) 2GB
64-bit: (CPU) 2.4 GHz Core 2 Duo / (Memory) 4GB
32-bit: (CPU) Core i3, i5 or i7 1.07 GHz Duo / (Memory) 2GB
64-bit: (CPU) Core i3, i5 or i7 1.07 GHz Duo / (Memory) 4GB
Windows® Windows 7
32-bit: (CPU) 2.0 GHz Core 2 Duo /(Memory) 2GB
