Mixer audio MIDI American Audio 14 MXR
UNREAD_POSTde djcristian » Vin Dec 28, 2012 1:10 pm
Ma bate gandul sa achizitionez noul model de mixer audio American Audio 14 MXR. Controlul MIDI pe care il ofera mi se pare extrem de util. Faptul ca are asemenea dotari si un pret mai mic chiar si decat al unui Behringer DJX750, mixerul pe care il folosesc acum, ma pune un pic pe ganduri asupra fiabilitatii pe o perioada mai indelungata de timp insa nu poti fi sigur de nimic niciodata, nu ? Behringer-ul il am de aproape 3 ani si functioneaza totul ok. Nu ati auzit de mixere Pioneer sau A&H la care s-a stricat ceva in primul an de utilizare ? Eu am auzit de astfel de patanii ale unora, cu astfel de echipamente "infailibile".
In viitorul apropiat cred ca imi voi incerca norocul cu un 14 MXR, sa vedem cum sta treaba cu el. Sper sa intre in geanta DJX-ului :P !
14 MXR -
The American Audio MXR Series offers DJs the tactile feel and operation of a traditional DJ mixer while playing and controlling music from software on their computer.
The 14 MXR is a 4-Channel MIDILOG™ Mixer with Midi/Analog control, built-in DSP D-Core Sound Card with 4-In/4-Out audio interface, Balanced XLR Outputs, MIDI Navigation Controls and user assignable control buttons to make it easy to customize and play your music.
Specifications:
• 14-inch, 4-Channel MIDILOG™ Mixer (compatible with any “Midi Learn” Software or Analog Inputs – such as CD Players, Turntables, etc.)
• Inputs: 4 Line, 2 Phono, 2 Mic
• 20 On-board Midi Control Buttons (Mapable)
• MIDI interface (USB MIDI I/O)
• Built-in DSP D-Core™ Sound Card with 4-In/4-Out audio interface
• Controller Mode: When activated USB output streams are routed through master and headphone outputs
• Balanced XLR Outputs
• 3-Band EQ with Rotary Kills (Treble, Mid & Bass)
• Midi Navigation Controls to allow easy software navigation of your music library
• Crossfader Curve Adjustment
• Crossfader Channel Assign
• Master, Booth, Headphone Level & Mix Controls
• Microphone Volume Control, Talkover + 3-Band EQ (Treble, Mid & Bass)
• Low/High Pass Filter with Bandwidth Control per channel
• 10 segment VU meter
• Audio inputs: RCA
• Microphone inputs: 2x Balanced ¼”/XLR Combo
• Headphone input: ¼” Stereo
• Multi-voltage operation: AC 100V~240V 50/60Hz
• Dimensions (LxWxH): 14.25”x13.75”x 3.5” / 356x320x85mm
• Weight: 10 lbs. / 4.5 kg.
