American Audio MRAY 4 SYSTEM
UNREAD_POSTde djcristian » Vin Dec 28, 2012 12:56 pm
Sistemul MRAY a aparut in 2011 si ar fi trebuit sa faca senzatie printre punatorii de muzica din toata lumea.
Eu personal nu am vazut inca unul in actiune pe la vreun eveniment si nici macar la vanzare in magazinele de profil din Romania. Initial s-a spus ca va avea pretul de 1600 $ si acum il vad pe site-ul American Audio la 2400$. S-or fi gandit ca e prea ieftin si de-aia rade industria de ei asa ca au mai adaugat niste sute bune de dolari la pret ca sa dea bine :) .
Ce s-a intamplat oare de nu a prins ideea acestui sistem ? E chiar asa de ciudat sau greu de transportat un astfel de sistem ? Nu se simte o diferenta notabila fata de un sistem conventional 2 topuri plus un sub ? A avut cineva ocazia sa auda acest sistem audio live ?
MRAY 4 SYSTEM -
ARRAY Style Speaker System Includes:
• 1 x Subwoofer with 3-Channel Amplifier
• 2 x Array Speakers
• 2 x Speaker brackets (Stands not included)
SPECIFICATIONS:
• 2 MIC inputs - Gain (1/4 inch)
• RCA Line input
• XLR Input/XLR Input
• XLR Output line for multiple units
• Adjustable high cut filter (80-200Hz)
• Sub Phase (0°- 180°)
• Sub woofer independent volume
• Low cut filter 22, 80, 125 (Sub only)
• Balance control EQ low
• +10/-10 2 band EG log + high
• Multi-voltage switch: 120V/60Hz or 230V/50Hz
• NL4 connection to speaker
• 500W RMS Sub @ 8 ohms
• 150W RMS x 2 speakers @ 8 ohms
• Signal, Clip and Protect LED indicators (x3)
SUBWOOFER:
• Casters for easy transport
• Built-in handles
• Ported sub
• Impedance: 8 ohms
• Frequency Response: 40Hz-800Hz
• Power Handling: 200W(RMS)/600W(Peak)
• Low Frequency: 15''(385mm), 2.5''(65mm)Voice coil
• Sensitivity: 100dB
• Dimensions: 21 x 25 x 18 in. / 514 x 635 x 458mm
• Weight: 110 lbs / 50kg
ARRAY SPEAKERS:
• Array style speakers
• NLA connectors
• Spring wire connectors
• 2 x 12 foot Neutrik cables
• 2 x Curve pole mount adapters with necessary hardware
• Impedance: 8 ohms
• Frequency Response: 120Hz-18kHz
• Sensitivity(1w/1m): LF 92dB/HF:102dB
• Nominal Coverage Angle(-6db): Horizontal: 60-degree /Vertical Splay: 20-degree
• Input Connectors: Speakon x2+Screw connect
• Low Frequency Driver: 5''(118mm), 1.0''(25.5mm) Voice coil x 4
• High Frequency Driver: 25mm voice coil, 1''(25mm) throat x 4
• Dimensions: 16 x 10 x 5.4 in. / 408 x 250 x 135mm
• Weight: 9 lbs / 4 kg.
3-Channel Amplifier:
• Output Power: 1 x Subwoofer: 450W (RMS) +2 x Arrays: 150W (RMS)
• Input Connectors: 2x LR
• Output Connectors: 2xLR+2 Speakon
• Controls: 2-Band EQ: Subwoofer, Level, Master
Re: American Audio MRAY 4 SYSTEM
UNREAD_POSTde MajNooN » Vin Dec 28, 2012 2:38 pm
Mi se pare foarte slab pentru banii astia. In plus, arata urat :P
100dB pt subwoofer? sigur nu e spl la 1w/1m, e la puterea rms...
LE: mai are si 50 de kile... :shock:
UNREAD_POSTde cris » Dum Dec 30, 2012 10:43 am
Cred ca nu e mare lucru de capul lui. La 500W rms pe sub, e slabut. Probabil ca a fost gandit pentru small party ori pentru conferinte, acolo unde dispersia mare e necesara si nu puterea concentrata. Ptr dj (mobil sau nu) nu e o solutie. Ai nevoie de putere concentrata pe ringul de dans. L-am vazut si pe la 1.700 $ http://www.bhphotovideo.com/c/product/8 ... ystem.html
insa nu e deloc convingator.
Pentru line array sunt solutii ceva mai bune. E drept ca si mai scumpe:
http://www.dbtechnologies.com/index.php ... _amdbt_pi1[category]=33&tx_amdbt_pi1[product]=425&cHash=b46e5db080a8da18b832946145676823
Un astfel de sistem l-am auzit intr-un mall din bucuresti si nu suna deloc rau pentru hala in care sonoriza. Dar suburile sunt colosal de grele. Asa ceva e util doar firmelor mari, care sonorizeaza spatii largi si care au 3-4 oameni la montaj. Oricum e greu de transportat.
