[VAND] pereche platane SYNQ
UNREAD_POSTde RObinetu » Mie Noi 25, 2009 3:32 pm
Vand pereche platane SYNQ plus cutii. 2000ron usor negociabil.
Very High Torque Direct Drive motor: 4.5kg.cm
Extremely fast start, adaptable from 0.2 to 6 sec.
Extremely fast stop, adaptable from 0.2 to 6 sec.
3 speeds: 33, 45, 78 rpm with quartz lock
3 Pitch adjustment ranges: +/-10% +/-20% +/-50%
Forward / reverse play
2 Start / stop buttons for maximum flexibility
Unbreakable white LED target light
All metal S-shaped tone arm assembly with:
Counterweight
Height adjustment with locking
Anti-skating adjustment
Lever lift with height adjustment
Adjustable large feet for perfect leveling
NEW: phono/line switch: connect your turntable to any input on your mixer!
Technical Information
Motor: 16 pole, 3phase, brushless DC motor
Driving Method: Direct Drive
Starting Torque: More than 4.5kg / cm
Starting Time: 0,20 ~ 6,00 seconds (adjustable)
Braking Time: 0,20 ~ 6,00 seconds (adjustable electronic brake)
Speed selection: 331/3 ~ 45 ~ 78 RPM
Speed adjustment: +/-10% ~ +/-20% ~ +/-50%
Tone arm type: Static balanced S-shaped tone arm.
Tracking Error angle: Less than 3?
Cartridge weight: 13~18g.
Anti-skate range: 0~3g.
Power supply: 230V~ 50Hz.
Power consumption: 13Watts
Dimensions: 450 x 353 x 86mm (WxDxH)
Weight : 11kg
Pt detalii PM sau mail.
RObinetu
UNREAD_POSTde scarface » Mie Noi 25, 2009 7:16 pm
Ai putea te rog sa redimensionezi pozele? ... Eu nu inteleg nimik din ele.
UNREAD_POSTde demential » Mie Noi 25, 2009 7:19 pm
eu am pus pozele. daca nu ti se vad inseamna ca ai o rezolutie execrabila la monitor :)
UNREAD_POSTde scarface » Mie Noi 25, 2009 8:53 pm
Am monitor de 15`` la laptop, poate vei intelege de ce nu suport sa vad pozele asa :wink:
UNREAD_POSTde demential » Mie Noi 25, 2009 9:22 pm
pai si eu am tot 2 laptopuri de 15 ;) si se vad:)
UNREAD_POSTde AndiBAD » Mie Noi 25, 2009 9:36 pm
Nici mie nu mi se vad (vezi k ee redimensionare pt 15'' si gati tot balciu)in plus am explicat si la mod de a atasa o poza!
UNREAD_POSTde RObinetu » Mie Noi 25, 2009 10:35 pm
Pentru cei interesati... daca vreti puteti sa le vedeti "in persoana", pentru probe anuntati-ma daca vreti sa le probati, ca sa fac rost de doze. Ele au functionat cu doze Ortofon Nightclub DJ E(liptic) tip Concorde si 95% pe Traktor Scratch.
RObinetu
Re: [VAND] pereche platane SYNQ
UNREAD_POSTde demential » Joi Dec 09, 2010 10:31 pm
mai este valabil anuntul ?
