Vand 2 Boxe Active JBL EON 515 si Boxa Bas JBL EON 518
UNREAD_POSTde djstore » Mie Ian 08, 2014 11:07 pm
Vand 2 Boxe Active JBL EON 515 si Boxa Bas JBL EON 518 , primul proprietar cumparate noi cu factura
Se vand urmatoarele :
2 Boxe Active - JBL EON 515 stare buna atat estetic cat si functional , acizitionate noi cu factura .
1 Boxa Bas Activ - JBL EON 518 S stare buna atat estetic cat si functional , achizitionat de asemenea nou cu factura .
Se vand numai la pachet ( sateliti si bass ) - pretul fiind de 1500 Euro negociabil ;
Nu se accepta schimburi .
Telefon : 0745 30 34 29 sau mail edy_vip_1999@yahoo.com
Mai jos gasiti caracteristicile tehnice ale echipamentelor :
Boxa Activa JBL EON 515 :
•System Type: Self powered 15", two-way, bass-reflex design
•Frequency Range (-10 dB): 39 Hz -20 kHz (EQ in ‘Flat’ position)
•Frequency Response (±3 dB): 42 Hz - 18 kHz (EQ in ‘Flat’ position)
•Coverage Pattern: 100° H x 60° V nominal
•Directivity Index (DI): 9 dB
•Directivity Factor (Q): 8
•Crossover Frequency: 2.2 kHz
•System Power Rating: 450 W continuous, 900 W peak
•LF Power amp: 350 W continuous at driver impedance
•HF Power amp: 100 W continuous at driver impedance
•Distortion: Less than 0.1% at rated power
•Maximum SPL: 129 dB
•Signal indicators: Limit: Red LED indicates input overload condition
•Signal: Green LED indicates signal present
•Mic/Line: Red LED indicator
•Input Gain (input 3): Mic position: -Infinity to +40 dB
•Line position: -Infinity to +4 dB (+20 dBu Max signal input)
•Input Gain (input 1 & 2): -Infinity to +4 dB (+20 dBu Max signal input)
•Input Impedance: 64 K Ohms (balanced), 32 K Ohms (unbalanced)
•Boost EQ: LF +3 dB Shelving Filter @ 200 Hz
•HF +2.5 dB Shelving Filter @ 4 kHz
•Low Cut Filter: Preset high pass @ 120 Hz
•LF Driver: 1 x JBL 265F-1 380 mm (15 in) Differential Drive® integrated
•woofer with dual 2" voice coils
•HF Driver: 1 x JBL 2414H 25.4 mm (1 in) neodymium compression driver
•Input 3 connector: Balanced XLR / ¼ inch TRS combo jack with XLR loop through
•Input 1 & 2 connectors: Balanced ¼ inch TRS jack
•Output (Loop/Mix switch): Balanced male XLR, +20 dBu (peak) o/p level in MIX position
•XLR Pin Assignments: Pin 2 (+), Pin 3 (-), Pin 1 (GND)
•Limiting/Protection: Dynamic Limiter
•Enclosure: PP impact copolymer, multi-purpose main & monitor orientation.
•Handles: One left/right side, one on top, with rubber grip
•Suspension / Mounting: 36 mm pole socket with stabilizing screw, 4 x M10 suspension
•points, 1 x M10 pull-back point
•Grille: Powder coated perforated steel with acoustically transparent
•black screen backing.
•AC input: 120 – 240 V, 50/60 Hz
•Dimensions (H x W x D): 685 x 438 x 366 mm (27.0 in x 17.3 in x 14.4 in)
•Net Weight: 14.8 kg (32.5 lb)
BOXA BAS ACTIVA JBL EON 518 S
•System Type: Self powered 18", bass-reflex design
•Frequency Range (-10 dB): 36 Hz - 130 Hz
•Frequency Response (±3 dB): 42 Hz - 100 Hz
•Crossover Frequency: 120 Hz (HPF selectable on outputs)
•System Power Rating: 500 W continuous, 1000 W peak
•Input Gain: - Infinity to +4 dBu
•Input Impedance: Nominal 20k Ohms (balanced)
•Polarity: 0° or 180° phase shift
•LF Driver: 1 x JBL 268G 460 mm (18”) Differential Drive® integrated
•woofer with dual voice coils, 4 ohm impedance
•Enclosure: 18 mm, plywood
•Suspension / Mounting: 36 mm pole socket on top
•Finish: DuraFlex™ finish
•Input Connectors: Balanced XLRs with loop through (stereo) to balanced XLR
•satellite outputs. ." Speaker level input.
•AC input: 120 – 230 V, 50/60 Hz
•Dimensions (H x W x D): 617 mm x 569 mm x 652 mm (24.3 in x 22.4 in x 25.7 in)
•Net Weight: 29.5 kg (65 lb)
Date de contact:
• Numar de telefon: 0745 30 34 29
• Adresa e-mail sau IM: edy_vip_1999@yahoo.com
djstore
