Vand boxe Montarbo W17A
UNREAD_POSTde patratzel » Mar Oct 08, 2013 11:42 am
M-am hotarat,vand cele 2 FR Montarbo W17A.
Din punct de vedere estetic -8
Din punct de vedere tehnic/functional-10
M-am saturat sa le car ! Singurul lor dezavantaj ,SUNT GRELE !
Pretul lor este de 1200 de Euro negociabil,1000 de euro Ultimul pret!
O sa fac si ceva poze,in viitorul apropiat !
Technical specifications :
Enclosure: 2 way bass-reflex
Frequency response: 40Hz ÷ 20kHz
Sensitivity (1W, 1m): 101 dB
Max SPL: 130 dB
Components (custom): 15" neodymium magnet woofer
1,4" driver with constant directivity horn (dispersion 60°H x 40°V)
Passive crossover: passive phase alignment network
Electronic crossover: 1 kHz, 24dB/Oct (Linkwitz-Riley)
Construction: High density polyethylene
6 fly points integrated in the cabinet shape
Steel protection grille
Side handles
Stand adapter
Amplifier 2 MosFet, class AB, amps controlled by 2 independent active dynamic processors
Max. output power: 450 + 150 W (8 ohms / 0,1% THD) Bass: 450 W
Mid/High: 150 W
Connections: balanced XLR input and output (link) wired in parallel
Dimensions (WxHxD) 480 x 740 x 405 mm
Weight 32 kg
Patratzel
0765450391
patratzel
Localitate: Focsani
