Vand subwoofer RCF SUB 718-AS
UNREAD_POSTde iulianrugina » Mar Sep 03, 2013 9:35 am
Vand un subwoofer RCF SUB-718AS, achizitionat pe 20 ian, deci mai are garantie inca 40 luni, arata si functioneaza perfect. A fost tinut si transportat numai in husa profi, nu are lovituri sau zgaraieturi, Ceea ce vedeti in ultima poza este volumul maxim pe care l-am putut folosi...Pret - 4200 ron cu tot cu husa. Telefon - 0722329584. Nu fac schimburi, doar cash. Poze reale. AVANTAJ CLIENT - CEL PUTIN 1800 RON !!!!!
Caracteristici:
1400 Watt Peak, 700 Watt RMS digital amplification
132 dB max spl
18" High power woofer, 4" voice coil
Xover selector, phase switch and high pass outputs
Electronic equalization, soft limiter and protection
Stereo Xlr/Jack combo input, Stereo Xlr signal output
Acoustical Specifications
Frequency Response -3 dB:40 Hz ÷ Xover point Hz
Max SPL:132 dB
Woofer:18", 4" voice coil
Input/Output Section
Input connectors:Combo stereo Jack-XLR male
Output connectors:Combo stereo XLR female
Processor Section
Crossover frequencies:80 - 120 Hz
Protections:Limiter
Limiter:Fast limiter, rms limiter
Controls:Volume, phase, crossover switches
Amplifier Specifications
Total power:1400 W PEAK
Low frequencies:1400 W PEAK
Total power:1000 W RMS
Cabinet
Cabinet Material:Baltic Birch
Handles:2 on sides
Pole Mount/Cap:yes
Colour:Black
Physical Specifications
Height:650/25.5 mm/inch
Width:504/19.84 mm/inch
Depth:650/25.5 mm/inch
Net Weight:40.4/89.06 kg/lbs
Re: Vand subwoofer RCF SUB 718-AS
UNREAD_POSTde iulianrugina » Mie Sep 04, 2013 10:02 am
se poate inchide. rezolvat!! schimbat cu rcf sub 905-as nou !!!!
UNREAD_POSTde The_Mack » Mie Sep 04, 2013 1:44 pm
sa il stapanesti sanatos - 10kg in minus se cunosc la maxim cand e dimineata pe racoare ;)
UNREAD_POSTde iulianrugina » Mie Sep 04, 2013 8:57 pm
The_Mack scrie:sa il stapanesti sanatos - 10kg in minus se cunosc la maxim cand e dimineata pe racoare ;)
merci mult!!! deja se cunosc numai cat l-am carat azi !!!
UNREAD_POSTde Interpret&Dj » Mie Sep 04, 2013 11:39 pm
Gata Iulian? Ai rezolvat-o? Imi vine si mie marti 705AS,are 32 kg,ma descurc cu el ;)
Formatie sau Dj? Eu sunt alegerea potrivita
Interpret&Dj
Localitate: Breaza
