Moving Head LED BEAM 10W x 12 (4 in 1) NOU !!!
UNREAD_POSTde djpaul » Lun Apr 22, 2013 1:41 pm
Light source and optics
12 x 10W high-efficiency CREE WW/CW White LEDs
Lux @5m: 1'500
Colour synthesis: RGBW FullColor mixing (>16 million colours) for a limitless colour range and variable CTC control
White temperature presets: 2700K~6000K
Beam angle: 12°
LEDs average life span: >50'000 h
Dimmer/Shutter/Strobe
0-100% linear dimmer
4 different dimming available curves
Independent shutter and fading effects with adjustable speed
Strobe: Electronic, 1-30 flash per second
Electronics
LCD display for a simplified access to control menu, configuration and DMX addressing
Master/Slave mode for stand-alone operations
Edit mode: creation and memorization of custom shows (up to 255 steps) directly from LCD user interface
Sound mode: sound activation through built-in microphone with sensitivity adjustment
Linear and “stepless” transition between DMX values
Flicker-free operations (400Hz)
2 DMX available configurations: 10 channels (8 bit) and 20 channels (16 bit) for basic or advanced control modes
Indipendent quadrant control for for pixel map effect or multi-coloured beams
Unit reset: through control panel or via DMX
Cooling: forced air, protection against overheating
Structure and moving body
High resistance and flame retardant polymer case in black colour
Internal protection: IP20
Power cable (shuko 1,5mt) included
Motion Angle: Pan = 630° Tilt = 200°
Pan/Tilt resolution: 8-bit or 16-bit:
Pan = 2,47° Pan Fine = 0,01° Tilt = 0,78° Tilt Fine = 0,004°
Suspension and fixing: any possible working position through omega kit (included)
Power supply
Power unit: 100-240V 50/60Hz
Max power consumption: 150W
Weight and dimensions
Weight: 5,8 kg
Dimensions (WxHxD): 258x285x149 mm
PRODUSUL ESTE NOU ! CUTIA A FOST DESFACUTA DOAR PENTRU PROBA !
PRET: 390 EURO/Buc. + CHELTUIELI DE TRANSPORT (DISPONIBILE IN STOC 2BUC.)
TEL: 0722 897 323
djpaul
Localitate: Alba-Iulia
