Vand schela de lumini Athletic R-KIT noua !!!!
UNREAD_POSTde iulianrugina » Vin Mar 29, 2013 10:06 pm
Vand o schela de lumini absolut noua, folosita o singura data in septembrie la o nunta. Cumparata de pe E-sound in septembrie, e nou-nouta in ambalaj original. Pret - 500 ron. Telefon - 0722329584.
Poze reale...e in cutie ....
A professional lighting structure made of 2 three-arm trusses of total length of 3,000 mm mounted on supports and two LS-4 lighting stands. The set allows to mount up to 8 lighting outlets. Advantages of the set include easy and simple assembly. Thanks to the optional cases, the set can be easily transported.
weight – 21,00kg
material – steel & magnesium
width – 3000mm
height - 1500mm - 3150mm
pipe diameter – 28mm
load capacity – 80kg
available colours - black
Includes: 2x LS-4, 2x R-150, 2x RPG-LS
Re: Vand schela de lumini Athletic R-KIT noua !!!!
UNREAD_POSTde iulianrugina » Sâm Mar 30, 2013 10:25 pm
vanduta . se poate inchide.
