vind subwoofer activ Gemini GVX-SUB18P
UNREAD_POSTde GABI » Sâm Mar 16, 2013 12:07 pm
vind subwoofer activ Gemini GVX-SUB18P 500W rms 2000W peak
18" woofer w/ 3" (76.2 mm) voice coil and 62oz magnet
Built in amp with limiter circuit
Perforated steel mesh grille
Recessed flush handles
Water resistant textured black paint
Balanced XLR/ 1/4" (6.35 mm) combo Input
Balanced XLR Full range Output and High Pass output
Electronic crossover w Adjustable frequency control (55Hz ~ 200Hz)
Linear frequency response between 37Hz - 250Hz
Phase inverter switch
35mm Pole mount fitting
pret 12 mil urgent . lam cumparat in 2011 septembrie de la audiomal cu pretul de 25 de mil tel 0740516387 pozele sint reale am factura la el , . am nevoie de bani
GABI
