Vand placa M-AUDIO 1814,Shure SM58,AKG D770
UNREAD_POSTde Dj Billy » Joi Mar 07, 2013 1:57 pm
1. Placa de sunet externa, M-AUDIO FireWire 1814 si soft PRO TOOLS 8 by digidesign, cu licenta. Placa functioneaza perfect, are usoare urme de uzura. Pret 300 euro, usor negociabil.
Sample rates: 44.1 to 192 kHz on all analogue outputs and analogue inputs 1/2; 44.1 to 96 kHz on analogue inputs 3 to 8.
Analogue inputs: two, balanced XLR with switchable global +48V phantom power and 1.8k(omega) impedance, or unbalanced TS quarter-inch jack instrument with 500k(omega) impedance, both using mic preamp with up to 66dB gain plus optional 20dB pad, or unbalanced line-level TS jack at fixed -10dBV sensitivity and 10k(omega) impedance, plus six further identical unbalanced line-level TS jacks.
Analogue outputs: four, balanced/unbalanced TS quarter-inch jack at -10dBV level, two headphone with individual level controls.
Digital I/O: ADAT optical in and out switchable to S/PDIF optical, co-axial phono S/PDIF in and out (both S/PDIF outputs support AC3 and DTS formats), MIDI In and Out, two six-pin Firewire ports, word clock in and out (will sync to external word clock at sample rates up to 96kHz).
Frequency response: 22Hz to 22kHz ±0.1dB at 48kHz sample rate, 22Hz to 80kHz ±1dB at 192kHz sample rate.
Dynamic range: inputs 105dBA, outputs 107dBA.
THD + Noise: less than 0.003% at -1dBFS.
Dimensions: 10.5 x 7 x 1.875 inches.
Weight: 3.44lbs.
2. Microfoane SHURE SM58 si AKG D770, ambele in stare de functionare perfecta. Shure-ul este original si este varianta cu buton on/off. Se vinde cu husa de la un Shure Beta si un cablu balansat de cca 5m. AKG-ul are cutia originala si cu buretele din interior, nuca stativ si cablu balansat de cca 4m. Pret pentru ambele (la pachet) 500 lei.
Separat, shure 350 lei si akg 250 lei. Pentru schimburi, valoarea lor este de 700 lei.
Dj Billy
Re: Vand placa M-AUDIO 1814,Shure SM58,AKG D770
UNREAD_POSTde Dj Billy » Lun Mar 18, 2013 12:15 am
Valabil.
Schimb cu masina de fum greu, par led, schela lumini...etc. Astept oferte/propuneri.
Am si 2 scanere Eurolite TS-5, impecabile, pentru cine este interesat.
Dj Billy
UNREAD_POSTde Dj Billy » Joi Mar 21, 2013 12:09 am
Sure-ul pleaca maine. AKG-ul il pastrez.
Sus cu placa de sunet si softul. Pret nou (URGENT), 1000 lei sau 1200 lei la schimburi.
Dj Billy
