VAND MIXER 19" OMNITRONIC EMX-5
UNREAD_POSTde djpaul » Joi Feb 14, 2013 5:00 pm
SPECIFICATII:
Power supply: 230 V AC, 50 Hz ~,
Power consumption: 30 W
Inputs:
DJ MIC (front): combined XLR (3-pin)/ 6.3 mm jack (1/4") (bal.)
MIC 1,2 (rear): 6.3 mm jack (1/4") (bal.)
Impedance: 1 kohms
Minimum input voltage: 1.5 mV RMS
LINE 1-5: stereo RCA
Impedance: 27 kohms
Minimum input voltage: 150 mV RMS
PHONO 1,2: stereo RCA
Impedance: 47 kohms
Minimum input voltage: 3 mV RMS
Outputs:
MASTER: stereo RCA, stereo XLR (3-pin)
ZONE: stereo RCA
Impedance: 400 ohms
Output voltage: 1 V RMS/ 0 dB
REC: stereo RCA
Impedance: 5 kohms
Output voltage: 225 mV RMS
Headphones: 6.3 mm stereo jack (min. 16 ohms)
Tone control (DJ MIC):
1 x High: -12 dB to +12 dB/ 1 kHz, ±1 dB
1 x Low: -12 dB to +12 dB/ 1 kHz, ±1 dB
Tone control (channels 1-5):
5 x High: -12 dB to +12 dB/ 1 kHz, ±1 dB
5 x Mid: -12 dB to +12 dB/ 1 kHz, ±1 dB
5 x Low: -12 dB to +12 dB/ 1 kHz, ±1 dB
S/N ratio: >80 dB
Frequency range: 20-20000 Hz
Distortion: 0.02%
Dimensions (WxHxD): 483 x 179 x 94 mm (19", 4 U)
Weight: 4 kg
PRET: 650 LEI + CHELTUIELI DE TRANSPORT !
PRODUSUL ESTE NOU !
TEL: 0722 897 323
djpaul
Localitate: Alba-Iulia
