VAND MIXER 19" DENON DN-X500 NOU IN CUTIE !
UNREAD_POSTde djpaul » Mar Feb 12, 2013 1:00 pm
PRODUSUL ESTE NOU IN CUTIE !!!
Matrix Input Assignment
No longer does your device need to be married to a particular Channel. Eight
input sources are freely assignable to any channel or even multiple channels.
8 Line / 2 Phono Switchable
4 Smooth 60mm VCA Channel Faders
Responsive 45mm VCA Cross Fader with Contour Adjust
Independent Channel PFL Meters
All input levels can be pre-adjusted in advance to match the gain levels, insuring a smooth transition between fades.
Independent 3-Band EQ Kill (high-mid-low)
Independent EQ On/Off Switch
Booth Output Assign Selector
Pre-monitor any channel including Master through the booth output in the same manner as you would with your headphones, with volume control!
External Send/Return Control
– Multi Channel Assignable
– Effect On/Off
– Effect Cueing (Pre & Post)
– Effect Dry/Wet Knob
Independent Channel A-B Post Switch (crossfader)
Powerful Clean Headphone Output
Fader Start (5V pulse)
Cross Fader and Channel Fader-Start Trigger is compatible with all Denon DJ CD/MP3 players.
Other Features
* Compact 4U Rack Space with Recessed Rear Terminals
* Independent 3-band Main and Aux Mic EQ
* Independent CUE System (all channels)
* Mic Talkover Function with Sensitivity Adjustment
* Split /Cue Headphone Monitor with PFL Metering
* Master Output -10dB Attenuation Switch
* Master Output Stereo/Mono Switch
* Record Out - RCA/Unbalanced
* Subwoofer/Lighting Output with Frequency Adjust Ideal for powered speakers, powered amp or even a signal feed for lighting systems.
PRET: 2000 LEI + CHELTUIELI DE TRANSPORT !
djpaul
Localitate: Alba-Iulia
