>>> VAND DIFUZOARE 18" FANE COLOSSUS 18XB made in UK IEFTIN!
UNREAD_POSTde soundevents » Joi Ian 24, 2013 6:35 am
Vand 2 bucati difuzoare SH de 18 inch profesionale Fane Colossus 18XB 600 W AES, prima serie, originale, made in England...Produse de catre firma Fane Acoustic http://www.fane-acoustics.com
Descriere: "The Colossus 18XB is intended for use as a high output sub-bass driver either singly or in multiway systems. The unit features a 4 inch voice coil immersed in a symmetric magnetic field and centralized by using two suspensions in a dual arrangement to maintain ultra linearity and stability at high excursions. The heavily ribbed straight sided paper cone membrane is reinforced with high strength composite fibres to resist deformation under extreme loads. The driver handles 600 Watts (A.E.S.) continuous and can cope with peaks in excess of 2400 Watts. This is due to advanced thermal management in the form of a vented die-cast chassis and motor system using an internal heatsink coupled to a large vaned heatsink mounted on the rear of the unit. These measures effectively remove heat from the voice coil resulting in extremely low power compression. The Colossus 18XB is designed for use in 100 to 250 litre ported enclosures".
>Motivul vanzarii: vreau ceva mai compact.
>Fisa tehnica: http://alturl.com/iij7p.
>Detalii: http://forum.speakerplans.com/fane-18xb-600w-advertised-as-800w_topic26685.html.
Fotografii cu difuzoarele:
1. Primul difuzor, fara interventii, 100% original si functional:
Imagine Imagine Imagine Imagine Imagine Imagine ->Ceeace se observa pe calota este o cuta/incretitura a hartiei, nu este ruptura sau fisura, nu a fost deformata vreodata, calota este cea originala din fabrica.
2. Al 2-lea difuzor, are calota relipita, nu cunosc motivul interventiei, asa l-am luat. Este 100% original si functional, se poate observa ca este putin diferit prin faptul ca partea din fata a sasiului nu este vopsita si are lipit ceva material de etanseizare pe fata:
Imagine Imagine Imagine Imagine Imagine Imagine Imagine
3. Ambele difuzoare unul langa altul:
4. Masurate:
Imagine Imagine Imagine Imagine Imagine Imagine Imagine Imagine Imagine
5. VIDEO:
Testul a fost facut cu semnal direct, fara crossover, la volum mic (sa nu deranjez vecinii).
>>> View My Video <<<
>>>OFERTA de pret pentru ambele difuzoare: 1.100 RON FIX. Transport platit de cumparator.
>> difuzorul intact fara interventii:...........650 RON/bucata;
>> difuzorul cu interventii la calota:..........450 RON/bucata;
Practic ofer 2 buc difuzoare SH de firma sub pretul unui singur difuzor nou. Cred ca este o afacere mai mult decat OK pentru cumparator!
Predare personala cu proba in Brasov.
Trimit in tara cu ramburs prin curierat rapid.
Numai bine!
soundevents
