Electrovoice ZX4, Amplificator Crown XTI 2000
UNREAD_POSTde p3psitwist » Lun Sep 12, 2011 5:52 pm
2 sateliti Electrovoice ZX4
Chassis Size 381 mm (15")
Color Black
Input Connections Parallel Neutrik® NL4
Speaker Type Fullrange
Speaker Type Mid-High
Speaker Type Two-Way
Speaker Type Wedges
Frequency Response (-3 dB) 60 - 20000 Hz
Frequency Response (-10 dB) 42 - 20000 Hz
Internal Crossover Yes
Sensitivity 1 W/1 m 100 dB
Max. SPL/1m (calc) 132 dB
Coverage
(Nominal -6 dB) H° 90 °
Coverage
(Nominal -6 dB) V° 50 °
System Power Handling (Continuous/Program/Peak) 400 Watts
LF Transducer EVS15SF
HF Transducer DH3
Crossover Frequency 1500 Hz
Nominal Impedance (Passive) 8 Ω
Minimum Impedance 6.5 Ω
Flying Yes
Outdoor No
Height 686 mm (27.01")
Width 445 mm (17.52")
Depth 406 mm (15.98")
Weight Net 20.2 kg (44.53 lbs)
http://www.electrovoice.com/product.php?id=251
sunt ale unui prieten, toate au fost aduse de el din SUA, nu a fost niciodata umblat in ele!
pret fix 800 euro, fara schimburi!
pentru detalii 0765 122 985 Alex
Re: Electrovoice ZX4, Amplificator Crown XTI 2000
UNREAD_POSTde johnnydj » Lun Sep 12, 2011 9:35 pm
ce rms au boxele?
UNREAD_POSTde CreB0 » Lun Sep 12, 2011 10:47 pm
400 W RMS
UNREAD_POSTde p3psitwist » Lun Sep 12, 2011 11:09 pm
CreB0 scrie:400 W RMS
UNREAD_POSTde johnnydj » Mar Sep 13, 2011 12:02 pm
daca erau active ma bagam clar
UNREAD_POSTde Lucian » Mar Sep 13, 2011 3:44 pm
johnnydj scrie:daca erau active ma bagam clar
te-ai razgandit? :) ---- te citez: "..niciodata nu o sa imi iau boxe pe 15"
UNREAD_POSTde Sorinus » Mar Sep 13, 2011 7:20 pm
Lucian scrie:
Da mai da is EV solistii se dau in vant sa cante pe Ev si Dynacoarde...ce mai conteaza pe cat is :mrgreen:
UNREAD_POSTde johnnydj » Mie Sep 14, 2011 12:10 am
Lucian scrie:
pai vroiam pt petreceri mai mici gen botez unde merg singur ca sa nu mai car bass, sau cand e nevoie sa vin cu ele pe langa ce am...asa ca lucian daca iti place sa ma intepi mai intereseaza-te si cu cine te pui
UNREAD_POSTde p3psitwist » Mie Sep 14, 2011 12:39 am
am fost la o nunta cu 4 din astea bagate intr-un powemate 1000 ....m-au zapacit, am plecat cu dureri de cap de acolo asa de tare a fost muzica :|
bine pe langa ele mai erau pusi si 2 basi tot EV ...da nu stiu cu ce erau amplificati
UNREAD_POSTde johnnydj » Mie Sep 14, 2011 12:41 am
stiu pepsica cum se aud...eu pt live tot pe 12 merg dar cand ai nunta de 250-300 oameni ai nevoie de putere si ar fi fost perfecte dar daca is pasive nu ma incanta:( ...app am fost duminica la o nunta invitat aveau 2 topuri si 2 basi dynacord nunta de peste 400 de oameni si se auzeau perfect :)
UNREAD_POSTde Lucian » Mie Sep 14, 2011 11:02 am
Stai linistit man, chiar nu am nimic cu tine, vroiam doar sa subliniez zicala: "niciodata sa nu spui niciodata"
Ontopic: un UP si de la mine, boxele suna foarte bine!
UNREAD_POSTde johnnydj » Mie Sep 14, 2011 11:18 am
deci...pt live niciodata nu merg pe 15...pt alte aplicatii nu sunt probleme
UNREAD_POSTde p3psitwist » Dum Sep 18, 2011 6:06 pm
amplificatorul s-a dat azi au mai ramas boxele
pret 800 Euro!!
UNREAD_POSTde p3psitwist » Sâm Sep 24, 2011 1:28 am
niste poze mai clare cu panoul din spate
UNREAD_POSTde djstefnek » Lun Sep 26, 2011 3:02 pm
p3psitwist scrie:am fost la o nunta cu 4 din astea bagate intr-un powemate 1000 ....m-au zapacit, am plecat cu dureri de cap de acolo asa de tare a fost muzica :|
sorry....dar daca ai plecat cu dureri de cap...inseamna ca ai probleme cu boxele..NICIODATA DE LA Electro-voice NU PLECI CU DURERI DE CAP !!!!
Let`s speak music !
live-x powered
http://www.djstefnek.ro
djstefnek
