Vand mixer Behringer DDM4000, platane Synq, Laptop Acer
UNREAD_POSTde RObinetu » Vin Mai 20, 2011 12:35 pm
Se vand urmatoarele:
Laptop Acer Aspire 5720
Procesor: Intel Core 2 Duo T5250 @ 1.5GHz 2MB L2 (Merom 65nm)
Chipset: Intel GM965 - ICH8-ME
Memorie: 4GB DDR2 667Mhz CL4
Video: Mobile Intel 965 Express
HDD: Western Digital 250GB Sata-II 7200rpm 16MB
Network: LAN 10/100Mbits - Wireless b/g
Sunet: Boxe stereo / Iesiri casti + SPDIF / Line-in
WebCam-Card Reader-Slot ExpressCard
Monitor: 15.6" 1280x800
Windows 7 Ultimate x64 (instalat fresh)
Pret 1200RON
Mixer Behringer DDM-4000. Primul proprietar, fara probleme, uzura si alte defecte. Functioneaza impecabil, ofer posibilitatea de a-l proba chiar si pentru functia de midi controller.
32-bit digital DJ mixer with beat-synchronized sampler, 4 multi-FX sections, 2 BPM counters, digital crossfader and MIDI
4 Phono/Line stereo channels allowing up to 8 signal sources to be connected simultaneously
2 microphone inputs with Gain, EQ, Talk function and FX
4 stereo channels with Gain, programmable parametric 3-band EQ with Kill function, fader curve control and flexible crossfader assignment
Fully featured MIDI controller for your DJ software
Sophisticated sampler with beat-controlled loop function, real-time pitch control, sampler FX and crossfader start option
2 freely assignable and BPM-synchronized, high-quality FX engines (Bitcrusher, Resonator, Reverb, Flanger, etc.)
Ultra-fast, and accurate BPM counters for automatic BPM synchronization of sampler, FX, crossfader and external drum machines, etc. via MIDI
Digital crossfader with flexible curve adjustment, reverse button and automatic, BPM-synchronized crossfading
Dual-mode crossfader with innovative frequency-selective crossfading
Dedicated headphones section includes PFL mix/split and bass/snare boost functions
Recall your last mixer setting at the push of a button
Digital S/PDIF output for direct recording of your performance
Rack mount brackets included for ultimate flexibility
High-quality components and exceptionally rugged construction ensure long life
Pret: 1000ron
Pereche platane Synq XTRM1 stare perfecta, s-a pus de pe ele pe la vreo 3 petreceri private, primul proprietar si singurul utilizator al lor. Platanele vin cu Case-uri profesionale pentru transport si o pereche de doze Stanton (cu care nu s-a lucrat, pe ele fiind folosite Ortofon Concorde Nightclub DJ E). Se pot proba, functioneaza cu iesire line sau phono depinde de set-up. Platanele vin si cu cablurile de alimentare (evident) si cabluri RCA (90grade la un capat).
Very High Torque Direct Drive motor: 4.5kg.cm
Extremely fast start, adaptable from 0.2 to 6 sec.
Extremely fast stop, adaptable from 0.2 to 6 sec.
3 speeds: 33, 45, 78 rpm with quartz lock
3 Pitch adjustment ranges: +/-10% +/-20% +/-50%
Forward / reverse play
2 Start / stop buttons for maximum flexibility
Unbreakable white LED target light
All metal S-shaped tone arm assembly with:
Counterweight
Height adjustment with locking
Anti-skating adjustment
Lever lift with height adjustment
Adjustable large feet for perfect leveling
NEW: phono/line switch: connect your turntable to any input on your mixer!
Technical Information
Motor: 16 pole, 3phase, brushless DC motor
Driving Method: Direct Drive
Starting Torque: More than 4.5kg / cm
Starting Time: 0,20 ~ 6,00 seconds (adjustable)
Braking Time: 0,20 ~ 6,00 seconds (adjustable electronic brake)
Speed selection: 331/3 ~ 45 ~ 78 RPM
Speed adjustment: +/-10% ~ +/-20% ~ +/-50%
Wow & Flutter: less than 0,1% WRMS (JIS WTD)
Tone arm type: Static balanced S-shaped tone arm.
Tracking Error angle: Less than 3°
Cartridge weight: 13~18g.
Anti-skate range: 0~3g.
Power supply: 230V~ 50Hz.
Power consumption: 13Watts
Dimensions: 450 x 353 x 86mm (WxDxH)
Weight : 11kg.
Pret: 2300ron (tot pachetul)
Daca vreti si poze spuneti-mi ca la momentul postarii anuntului nu am avut posibilitatea.
RObinetu
Re: Vand mixer Behringer DDM4000, platane Synq, Laptop Acer
UNREAD_POSTde DJ Stef » Dum Mai 22, 2011 9:32 pm
salut, sunt interesat de laptop, cum ne putem intalni sa il vad daca se poate?
eventual intr-o seara...eu stau in zona titan
Decat sarac si bolnav mai bine bogat si sanatos
DJ Stef
UNREAD_POSTde p3psitwist » Dum Mai 22, 2011 9:40 pm
salut
pe mine m`ar interesa pick-upurile daca nu le dai pana pe 1 iunie...
am drum de fapt atunci pana la bucuresti si daca nu le dai si o sa am banii...poate vin sa le vad....si sa le iau...
UNREAD_POSTde RObinetu » Lun Mai 23, 2011 4:37 am
Pentru laptop, nr meu de tel 0721320293, asta pt ca nu am putut trimite PM, ne putem intalni cam oricand/oriunde. Pentru platane, deocamdata nu am cereri, contacteaza-ma inainte de drumul in Bucuresti, daca e cazul, si vedem cum facem.
RObinetu
UNREAD_POSTde RObinetu » Mar Mai 31, 2011 1:32 pm
Up! Fac si discount pentru cine e interesat.
RObinetu
UNREAD_POSTde p3psitwist » Mie Iun 01, 2011 11:05 pm
eu am renuntat la idee...ca nu mai am bani...
mi-am cumparat 2 microfoane
UNREAD_POSTde RObinetu » Joi Iun 02, 2011 1:05 pm
Asta e... GG :)
RObinetu
UNREAD_POSTde RObinetu » Dum Iun 05, 2011 4:40 pm
Up!
RObinetu
UNREAD_POSTde RObinetu » Joi Iun 09, 2011 12:41 pm
Up!
RObinetu
UNREAD_POSTde RObinetu » Mie Iun 15, 2011 3:56 pm
Up!
RObinetu
UNREAD_POSTde MajNooN » Mie Iun 15, 2011 10:29 pm
Niste poze cu laptopul se poate?
Si niste detalii... gen: de cand il ai... etc
UNREAD_POSTde RObinetu » Lun Iul 25, 2011 12:07 pm
Up!
Laptop-ul s-a dat!
RObinetu
UNREAD_POSTde prodan cezar » Mar Sep 27, 2011 9:58 pm
Buna seara, am doar 800 lei pt mixerul behringer ddm 4000, esti de acord?
[b]Sonorizari petreceri private, evenimente , corporate party[/b]
prodan cezar
Localitate: iasi
UNREAD_POSTde RObinetu » Joi Noi 24, 2011 7:58 pm
Up! Platanele si mixerul.
RObinetu
UNREAD_POSTde dymadj » Joi Dec 01, 2011 11:56 pm
e valabil?? zuzu_sound1
dymadj
UNREAD_POSTde DanceDj » Mar Dec 13, 2011 5:00 pm
Ma intereseaza platanele daca mai sunt valabile.
DanceDj
UNREAD_POSTde adrianho6 » Sâm Dec 17, 2011 6:13 pm
te intereseaza un schimb cu audio dj 4 ? sau x session pro plus diferenta
adrianho6
UNREAD_POSTde RObinetu » Dum Dec 18, 2011 4:15 pm
Salutare pentru cine este interesat, platanele mai sunt de actualitate, am incercat sa va dau PM dar nu situ de ce nu reusesc. Lasat-mi voi un PM cu datele de contact sau trimiteti-mi un mail pe ciprian_alexandru@yahoo.com.
RObinetu
UNREAD_POSTde dakytza » Mar Iun 05, 2012 3:12 pm
mai ai mixerul?
dakytza
