Vand Fujitsu Siemens W360 CORE2DUO E6550 2.33GHz 4GB DDR2
UNREAD_POSTde SetUp » Mar Mai 10, 2011 2:07 pm
Sistemul e foarte silentios.
Totul e racit pasiv, HDD ul e prins in cauciuc.
Nu este in carcasa originala
A fost adus din germania si nu am avut loc de toata cutia in avion asa ca am luat componentele. :oops:
Acum e intr-un full tower adaptat de mine, nu e cel mai aspectuos insa asta nu afecteaza performanta. Mie mi-a fost important sa il protejez.
Trimit poze reale la cerere.
Vine cu Windows 7 64bit proaspat instalat si configurat cu toate driverele.
Pret cu placa video nVidia 8500 cu 512MB DDR3 275 EUR negociabil.
(devine un sistem de gaming entry level)
Pret fara placa: 245 euro negociabil (fiind un calculator office puternic)
Optional mai pot adauga inca un HDD.
Specificatile mai jos si alte detalii [url="http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBgQFjAA&url=https%3A%2F%2Fglobalsp.ts.fujitsu.com%2Fdmsp%2Fdocs%2Fds-celsius-w360.pdf&ei=Q7DHTbm2KMmc-wbso52MCA&usg=AFQjCNGdse2bACb-hiucRWD8LT8uhjmNig&sig2=h-0pxdHi4q7PTuTy7cV7Cg"]aici[/url]
Il dau si pe componente dar numai dupa ce vand MB+Procesor.
Nu sunt interesat de nici un fel de schimb!
CPU Intel Core2 Duo E6550 2x2,33 GHz
Front Side Bus 1333 MHz
L2 Cache 4096 KB
RAM 4x1GB DDR2 800MHz (max 8GB)
HDD 160 GB
Optic DVD-Writer LG DL
Mainboard model D-2587
Chipset Intel Q35
Placa video / GPU On board Intel Q35 (max 128MB)
Conexiuni video VGA & DVI
Sunet On board - High Definition Audo
Chipset sunet Realtek ALC262
LAN 10/100/1000 MBits/s on Board
Conexiuni 4 x PCI, 6x SATA2 (cu RAID 0/1/5/10), 1 x PCI Express x1, 1 x PCI Express x4, 1x PCI Express x16, 10 x USB 2.0
Sursa 300 Watt reali (originala FSC)
SetUp
