BOXE ACTIVE JBL EON515 (2buc.)
UNREAD_POSTde djpaul » Joi Apr 07, 2011 12:58 pm
JBL EON515
System Power Rating : 450 W continuous/900 W peak
Frequency Range (-10 dB) : 39 Hz -20 kHz (EQ in ‘Flat’ position)
Dimensions (H x W x D) : 685 x 438 x 366 mm
Frequency Response (±3 dB) : 42 Hz - 18 kHz (EQ in ‘Flat’ position)
Coverage Pattern : 100° H x 60° V nominal
Maximum SPL : 129 dB
Net Weight : 14.8 kg (32.5 lb)
PRET: 1299 EURO + CADOU HUSE ORIGINALE !!!
PAUL - 0722 897 323
EON515 004.jpg (353.94 KiB) Vizualizat de 1783 ori
EON515 003.jpg (295.73 KiB) Vizualizat de 1783 ori
EON515 002.jpg (308.27 KiB) Vizualizat de 1783 ori
djpaul
Localitate: Alba-Iulia
Re: BOXE ACTIVE JBL EON515 (2buc.)
UNREAD_POSTde djpaul » Vin Apr 29, 2011 11:17 am
UP !
djpaul
Utilizatorii ce navighează pe acest forum: Bing [Bot] şi 3 vizitatori
