Vand boxe active JBL PRX515 VANDUTE!!!
UNREAD_POSTde carosoundmix » Joi Apr 07, 2011 10:14 am
Vand doua bucati JBL PRX515 active.
Incinte cumparate in iunie 2010, sunt folosite, insa in stare excelenta atat functional cat si optic.
1700e ambele bucati. Pret usor negociabil.
ACCEPT TESTAREA LOR FARA NICIO RETINERE.
Motivul vanzarii - upgrade.
Livrare gratuita in orasele resedinta de judet.
Nu sunt interesat de schimburi.
La cerere se pot trimite pe e-mail poze originale.
Contact: Florin 0751 220 490
Detalii tehnice:
System Type: Self powered 15", two-way, bass-reflex
Frequency Range (-10 dB): 45 Hz - 20 kHz (EQ in flat position)
Frequency Response (±3 dB): 52 Hz - 20 kHz (EQ in flat position)
Coverage Pattern: 70º x 70º nominal
Directivity Index (DI): 10.3 dB
Directivity Factor (Q): 10.8
Crossover Modes: DSP controlled 48 dB filter slope
Crossover Frequency: 1.6 kHz
System Power Rating: 500 W continuous, 1000 W peak
LF Power amp: Class-D, 400 Watt (continuous) at driver impedance
HF Power amp: Class-D, 100 Watt (continuous) at driver impedance
Distortion: Less than 0.1% at rated power
Maximum Peak Output: 133 dB
Signal indicators: Overload: Red LED indicates input overload condition
Signal: Green LED indicates signal present
Input sensitivity range: Mic position: -25 dBu to 0 dBu
Line position: +10 dBu to +28 dBu
Input Impedance: 64 K Ohms (balanced), 32 K Ohms (unbalanced)
EQ: Presets for Main and Monitor position
LF Driver: 1 x JBL 265F 380 mm (15 in) Differential Drive® woofer
HF Driver: 1 x JBL 2408H 37.5 mm (1.5 in) annular polymer diaphragm, neodymium compression driver
Enclosure: Trapezoidal, 18 mm, plywood with polypropylene end caps
Suspension / Mounting: Dual 36 mm pole socket
Transport: 2 x die-cast handles with backing cup
Finish: Anthracite DuraFlex™ finish
Grille: Powder coated, Anthracite, 18 gauge perforated steel with acoustical transparent black foam backing.
Input Connectors: Balanced XLR / 1/4 inch combo jack with XLR loop through
Dimensions (H x W x D): 815 mm x 440 mm x 465 mm
Net Weight: 26 kg (57 lb)
La cerere se pot trimite poze originale.
JBL PRX515 front back.jpeg (193.9 KiB) Vizualizat de 1881 ori
Ultima oară modificat de carosoundmix pe Sâm Apr 09, 2011 11:41 pm, modificat 1 dată în total.
carosoundmix
Localitate: Alba Iulia
Re: Vand boxe active JBL PRX515
UNREAD_POSTde demential » Joi Apr 07, 2011 10:29 am
salut si bine ai venit la noi pe forum.
te rog sa iti modifici datele din profil ;)
Re: Vand boxe active JBL PRX515 VANDUTE!!!
UNREAD_POSTde carosoundmix » Sâm Apr 09, 2011 11:42 pm
Vandute. Se poate inchide.
carosoundmix
