[CUMPAR] Masina de fum greu
UNREAD_POSTde SnakeBiteTWO » Mar Sep 01, 2009 8:21 pm
Salut!
As vrea sa achizitionez o masina de fum greu.
Daca stiti pe unde gasesc, va rog sa-mi dati si mie un link, ceva...
Multumesc!
Ultima oară modificat de SnakeBiteTWO pe Mie Sep 02, 2009 4:29 am, modificat 1 dată în total.
UNREAD_POSTde scarface » Mar Sep 01, 2009 10:41 pm
UNREAD_POSTde djdoru » Mar Sep 01, 2009 10:52 pm
djdoru
Localitate: Pitesti
UNREAD_POSTde SnakeBiteTWO » Mie Sep 02, 2009 4:30 am
DJ Doru am sa te caut in curand...
UNREAD_POSTde zeedoshop.ro » Vin Sep 11, 2009 2:33 pm
NB-40 ICE Low Fog
Universal Floor Fogger Stand-alone smoke-machine with fluid tank The smoke is cooled down and "converts" it into floor smoke No need for special fluid Remote control connection via 3-pin IEC socket With Volume/Timer remote control Operation via crushed ice
Power supply: 230 V AC, 50 Hz ~ Power consumption: 450 W Smoke-output: approx. 3 m Warm-up time: approx. 4 min. Tank capacity: 0.6 l Dimensions: 530 x 330 x 330 mm Weight: 7.5 kg
159 Eur / www.zeedoshop.ro
Zeedoshop.ro ofera discount pentru membri forumului!
zeedoshop.ro
UNREAD_POSTde zeedoshop.ro » Vin Sep 11, 2009 2:37 pm
Ice Pro
Power Supply: 240V/50 Hz Power Consumption: 900W Output: 5000 cu. ft/Min. Tank capacity: 5 L Fluid type: Fog Fluid DMX: Yes Dimensions: 605 x 410 x 370 mm Weight: 13 kg Accessories/ordering info: Remote: Timer-remote Controller (included) Special Reservoir for ice-cubes
ImagineImagine
232 Eur / www.zeedoshop.ro
zeedoshop.ro
UNREAD_POSTde zeedoshop.ro » Vin Sep 11, 2009 2:43 pm
Antari Professional
Output: 8000 Cubic feet/minute Tank capacity: 2.5 L Heater: 1040 W Dimensions: 617 x 355 x 359 mm (LxWxH) Gross weight: 28,6 kg Net weight: 24,4 kg
ImagineImagine
786 Eur / www.zeedoshop.ro
zeedoshop.ro
UNREAD_POSTde SnakeBiteTWO » Vin Sep 11, 2009 2:56 pm
Ok, multumesc!
Voi lua o decizie curand. Cea mai scumpa - Antari Professional - e de scena si nu mi-o permit.
Insa voi opta pentru una din celelalte doua.
Thanks again!
UNREAD_POSTde zeedoshop.ro » Vin Sep 11, 2009 3:08 pm
mai am una la vreo 7200 eur...:))
e un monstru:))
iti postez o imagine sa iti faci o idee.
Power AC240V Power Consumption (Compressor) 600W / 750 W Initial Start-up Current (Compressor): 4000W Heater: 3000W Output: 40,000 cu.ft / min First Heat-Up Time: 12 min Tank Capacity: 10 litres Fluid Consumption Rate: 11 min/ litre (100% output) Remote Included: D-20 (LCD Timer Panel Controller; 2 Metres) Accessory Included: 3M Fog Conducting Hose Optional Accessory: DNG-200 Flightcase Weight: 120 Kg Dimensions (mm): 780.00 W 607.80 H 686.30 Liquid Used: Low fog fluid (below) recommended DMX Channel used: 1 Additional information: Self contained unit-- no C02/Dry ice required Floor-Mount installations (4 wheels) DMX on-Board
ImagineImagine
in 11 min rade 1l de lichid. Dar face fum nu se incurca.
asta e buna pentru filmari.
am si masini de ceata si fum normal daca esti interesat.
zeedoshop.ro
UNREAD_POSTde SnakeBiteTWO » Vin Sep 11, 2009 3:15 pm
De una de-asta poate ar fi interesati cei de la Media Pro sau Kentauros.
Dar e mai simplu sa o inchirieze.
UNREAD_POSTde demential » Lun Sep 21, 2009 5:04 pm
sa ne zici daca ti-ai luat ;)
UNREAD_POSTde remy » Lun Sep 21, 2009 7:02 pm
adica fumul scos de nb-40 sta frumos pe jos si nu se ridica!? si merge cu lichid normal?
reply
UNREAD_POSTde zeedoshop.ro » Lun Sep 21, 2009 7:07 pm
sta frumos jos, pentru ca e lichid de low fog.
costurile sunt cam aceleasi.
zeedoshop.ro
UNREAD_POSTde remy » Lun Sep 21, 2009 7:24 pm
SI CAT COSTA LA TINE LICHIDUL LOW?
UNREAD_POSTde SnakeBiteTWO » Lun Sep 21, 2009 9:40 pm
Masina functioneaza cu lichid de fog normal, singura diferenta este ca fumul (vaporii) inainte de a pleca din duza finala, este racit de un modul de racire, care functioneaza cu cuburi de gheata carbonica.
Inca nu am achizitionat una, pentru ca ne apropiem de final de sezon, si ezit sa mai fac investitii...
Exista si lichid pentru low foggers.
UNREAD_POSTde zeedoshop.ro » Mar Sep 22, 2009 8:42 am
Tin sa te contrazic,
Exista si lichid de fum jos, fara a fi nevoie sa utilizezi gheata carbonica.
Poti folosi lichid de fum jos fara sa folosesti gheata chiar deloc.
In acelasi timp, poti folosi si lichid normal, cu gheata.
Uite cateva detalii:
Low Smoke Fluid:
This water based liquid is especially designed for fog/smoke machines to create a dense, white, low fog without the use of ice for entertainment use on stage, in theatre or television productions, in a discotheque or as a special effect. It has no unpleasant odour and leaves no oily residue. Non-irritant and non-flammable. Reliable for performers and compatible with most fog machines.
http://www.zeedoshop.ro/detalii.php?categ=231&id=8323
28,1 Eur[/img]
zeedoshop.ro
UNREAD_POSTde iulian » Mar Sep 22, 2009 10:35 am
am şi eu o întrebare , lichidul asta mere la orice tip de masina de fum ?
Caracterul unui om poate fi judecat după gusturile sale muzicale. (platon)
iulian
UNREAD_POSTde zeedoshop.ro » Mar Sep 22, 2009 12:10 pm
asta merge doar la low foggers. lichidul obisnuit merge la orice tip de masina de fum.
http://www.zeedoshop.ro/produse.php?categ=231
intra pe linkul asta si o sa gasesti tot ce iti trebuie.
zeedoshop.ro
UNREAD_POSTde demential » Mar Sep 22, 2009 12:19 pm
am o masina de fum antari. ce produs imi recomanzi pentru
1) odorizant .... se adauga peste lichidul pe care il am deja ?
2) cum o curat ? ai lichid special de curatat masina de fum antari ?
multumesc anticipat :D
UNREAD_POSTde zeedoshop.ro » Mar Sep 22, 2009 12:26 pm
ce model de la antari?
Odorizantele se pun il lichidul de fum. Se amesteca, si iese fum parfumat :))
Exista si lichid de curatare pentru masinile de fum.
E foarte important sa iti pastrezi duzele curate.
Iti recomand asta:
http://www.zeedoshop.ro/detalii.php?categ=231&id=1289
Ajunge pentru 5 curatari. Ar fi bine sa ii faci o curatare cam la 5l folositi.
ca parfumuri exista foarte multe modele si tipuri.
arunca o privire.
sper sa fie de ajutor:)
zeedoshop.ro
Înapoi la Vreau sa cumpar ...
