Vand 2 boxe pasive Yamaha C112V
UNREAD_POSTde Sorinus » Sâm Noi 15, 2014 11:35 pm
Vand 2 boxe pasive Yamaha C112V in stare perfecta optic si functional.
Le-am cumparat de Danyinthemix dar le tin degeaba.
Pret 500 lei bucata.
Specificatii:
Enclosure Bass Reflex Type
Speaker unit (LF) 12" cone
Speaker unit (HF) 2" V.C.driver
Frequency Response 60Hz-16kHz
Power Capacity (Program) 350W
Power Capacity (Maximum) 700W
Nominal Impedance 8 ohms
Sensitivity 97db SPL (1W, 1m)
Nominal Dispersion (Horizontal) 90°
Nominal Dispersion (Vertical) 40°
Crossover Frequency 2kHz
Input Connectors Barrier Strip Terminal
Included Accessories Eyebolt (3/8") 4
Dimensions Width 416mm
Height 620mm
Depth 329mm
Weight Weight 21.8kg
Poza preluata de la Danyinthemix.
Re: Vand 2 boxe pasive Yamaha C112V
UNREAD_POSTde Sorinus » Mar Noi 18, 2014 10:59 pm
S-au dat, se poate inchide multumesc!
