mixer cu efecte, difuzoare 15", basii 18"
UNREAD_POSTde Petre Augustin » Vin Iun 06, 2014 11:39 pm
PACHET: boxe pasive 2x15"+1" cu 4x HP15W, 2x BM-D446II + PH-2420 (numai stiu exact daca e codul corect la horn), 2x filtru PRO PA protectie cu bec halogen, ! Putere: 400W RMX/ buc , Trapezoidale Dimensiuni: 114cm x 50cm x 56cm x 31cm cu doua difuzoare de 15 inchi/boxa, full accesorizata, 51kg/ buc, Amplificator Tamp2400 - unic proprietar + cabluri boxe + mixer behringer 802 xenyx
PRET PACHET : 1900 RON - la activ pana in 10 evenimente tip nunta-botez-majorat
http://i57.tinypic.com/fejp90.jpg
http://i57.tinypic.com/4hv4hc.jpg
http://i61.tinypic.com/2a94rvs.jpg
http://i58.tinypic.com/20acdfn.jpg
http://i59.tinypic.com/4r3tiw.jpg
http://i61.tinypic.com/k2ee5t.jpg
http://i61.tinypic.com/11uggex.jpg
Sau daca se gasesc doritori se poate descompleta (difuzoarele se dau doar perechi - 2 buc si se gasesc in stare impecabila - f putine evenimente) pachetul astfel:
DRIVERE: P-audio BM-D446 + Horn 2420 - doua bucati drivere+hornuri la 400 RON
http://i59.tinypic.com/95vv6c.jpg
http://i58.tinypic.com/5flz6o.jpg
http://i62.tinypic.com/2d7h74n.jpg
http://i61.tinypic.com/20r1kbo.jpg
DIFUZOARELE Hp15W 15": P-audio HP15W - Pret: o bucata la 150 RON ( 4 difuzoare disponibile)
http://i60.tinypic.com/2ccnodj.jpg
http://i59.tinypic.com/160zio5.jpg
FILTRE PASIVE: P Audio cu protectie cu bec halogen - doua bucati la 150 RON
http://i57.tinypic.com/10eoagw.jpg
http://i62.tinypic.com/4rqrno.jpg
AMPLIF Tamp2400 - Pret: 950 RON transport inclus prin curierat
Mixer Alessis MultiMix8 FireWare - Pret: 600 RON - efect pe voce apropiat de dynacord, f reusit efectul
http://i59.tinypic.com/20u74pc.jpg
http://i58.tinypic.com/4si15i.jpg
Mixer Behringer xenyx 802 - Pret: 120 RON
http://i59.tinypic.com/svgje0.jpg
Cutiile pt fullrange 2x15"+1" - doua bucati full accesorizate: mochetate, tabla perforata protectie, burete fonotransparent protectie, manere din tabla rezistenta, picioruse de cauciuc, conectori neutrik dubli in spate, Toate accesoriile fiind luate de la P-audio - Pret: 150 RON perechea (cine cunoaste: pe rutele firmei OBADA TRANS se poate asigura transport)
http://i62.tinypic.com/v7e2kl.jpg
doua subwoofere pasive bass reflex cu C18 650 EL II - putere 1200W/ buc, impecabile, 40kg/buc, au functionat pe phonic xp3000 cu cross phonic pcx3000 - au la activ 5 evenimente tip nunta/botez in 2013, unic proprietar-achizitionate in martie 2103, acccesorii de la discopro, grilaj tabla perforata si burete fonotransparent, Dimensiuni: 700x512x600 , MOTIV: o dorinta puternica de a achizitiona un model anume de la discopro !
detalii difuzor: http://discopro.ro/Difuzoare_profesiona ... 18-650ELII
Pret 2 Buc. : 3700 RON usor negociabil
http://i62.tinypic.com/723prm.jpg
http://i60.tinypic.com/141t3s.jpg
http://i61.tinypic.com/avna07.jpg
http://i60.tinypic.com/2qisod2.jpg
http://i59.tinypic.com/2hwyxae.jpg
designul basilor sunt de genul:
http://i62.tinypic.com/28w314l.jpg
proiect de la discopro.ro
Contact: 0769 485 468
Ultima oară modificat de Petre Augustin pe Mar Iul 01, 2014 10:13 pm, modificat 1 dată în total.
Petre Augustin
Re: boxe pasive, drivere, difuzoare 15", basii 18",amplif,mi
UNREAD_POSTde Petre Augustin » Dum Iun 22, 2014 4:13 pm
se mai adauga produse ! up !
Petre Augustin
UNREAD_POSTde Petre Augustin » Lun Iun 30, 2014 10:04 pm
Au mai ramas urmatoarele :
Mixer Alessis MultiMix8 FireWare - Pret: 500 RON - efect pe voce apropiat de dynacord, f reusit efectul
DIFUZOARE Hp15W 15": P-audio HP15W - Pret: o bucata la 150 RON ( 4 difuzoare disponibile impecabile, fara abuz)
http://i61.tinypic.com/2ir21yu.jpg
doua subwoofere pasive bass reflex cu C18 650 EL II - putere 1000W/ buc, impecabile, 40kg/buc - au la activ 5 evenimente tip nunta/botez in 2013, unic proprietar-achizitionate in martie 2103, acccesorii de la discopro: grilaj tabla perforata si burete fonotransparent, picioruse cauciuc, manere tabla rezistente, conectori dubli neutrik, flansa stativ, Dimensiuni: 700x512x600 , Material: pal 18mm, MOTIV: o dorinta puternica de a achizitiona un model anume de la discopro ! -
!!! PENTRU CINE CUNOASTE, SE POATE ASIGURA TRANSPORT CONVENABIL PE RUTA OBADA SRL, sau POATE rezolvam si pe alte rute !
Pret 2 Buc. : 3300 RON
Petre Augustin
Re: mixer cu efecte, difuzoare 15", basii 18"
UNREAD_POSTde Petre Augustin » Lun Iul 14, 2014 12:36 pm
Mixer Alessis MultiMix8 FireWare - Pret: 480 RON - efect pe voce apropiat de dynacord, f reusit efectul
Pret 2 Buc. : 3000 RON
Daca se gasesc doritori poate descompletam basi/cutie bass reflex :
Petre Augustin
UNREAD_POSTde Petre Augustin » Mar Sep 01, 2015 9:36 pm
Se poate sterge. Multumesc
Petre Augustin
