STAIRVILLE LED BAR 240/8
UNREAD_POSTde djcristian » Lun Sep 16, 2013 11:10 am
Recent am achizitionat un nou tip de efect de lumina si anume o bara cu leduri STAIRVILLE de care sunt foarte incantat si pe care vreau sa o prezint comunitatii.
Specificatii tehnice :
Stairville LED Bar 240/8 ° 30 RGB DMX, LED flood bar fitted with 240x 10 mm LEDs. The LED thomann Bar 240/8 is ideally, Suitable when it comes to the colour and light design on stage, in Clubs, bars, etc Eight individual segments allow the LED bar to be controllable easily to create varied and very dynamic Surface effects. The RGB colou mixing thomann ensures, that the color tones are virtually limitless. By the LED display, all important functions can be setup and recalled easily, Specifications: Light Source: 240 pcs. Ø 10 mm LEDs (96 red, 72 green, 72 blue), 8 Control segments, Angle: 30 °,, Power supply: thomann AC90V/240V, 50Hz/60Hz Max. Power consumption: 36W, Control: DMX 512 (2, 3, 5, or 24 channels),, Master / Slave, Auto Run (internal programs), Sound-to-Light (via built-in microphone), Static Colour, Connections:, DMX Input and output: 3-pin XLR power input and output: IEC (IEC) material: thomann aluminum application: Ideal Operating tempertaures: -20 °C~+ 45° C, humidity: 0%-90%. incl. 2 pcs short bracket & 2 pcs. long bracket, Dimensions: 1064 x 65 x 88.5 mm, Weight: 2.6 kg
Pagina produs :
http://www.thomann.de/ro/stairville_led_bar_2408_rgb_dmx_30.htm
Produsul in actiune la un eveniment :
http://www.youtube.com/watch?v=lVlysWSp8f4
http://www.youtube.com/watch?v=H174QBb7qgE
Re: STAIRVILLE LED BAR 240/8
UNREAD_POSTde iulianrugina » Joi Oct 10, 2013 5:58 pm
e setata pe ``sound`` cumva?
UNREAD_POSTde DJ Sun » Joi Oct 10, 2013 6:41 pm
Aceasta lumina nu cred ca e destinata la ce o folosesti tu, cei 2 pari iti acopera complet aceasta lumina, nu ii vad rostul inafara faptului ca arata bine pe stativ.
I-ati mai multe si fa cu ele arhitecturala.
Parerea mea.
UNREAD_POSTde voxparty » Joi Oct 10, 2013 8:53 pm
ca si djSun zic ca aceasta lumina se preteaza mai degraba la iluminarea peretilor (de exemplu se poate pune in spatele dj-ului daca peretele este deschis la culoare)... in rest, ce sa zic, sa o folosesti sanatos :)
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 6 vizitatori
