[SERVICII]Inchiriere scena,sistem de sunet,lumini,tehnicieni
UNREAD_POSTde Proaudiostore » Mar Sep 01, 2009 9:09 pm
Oferim spre inchiriere sitem de sunet ,Scena si lumini.Descriere mai jos:
LATER EDIT :Sietmul de sonorizare este dublu ,acum,fata de ce e trecut mai jos.Deci nr de boxe se inmulteste cu 2 .
Sitem de sunet
12 x PEAVEY Line Array VERSARRAY 112
http://www.peavey.com/assets//images/ad ... 4090_3.jpg
8 x PEAVEY SUBWOOFER VERSARRAY 218
http://www.peavey.com/assets//images/ad ... 4470_3.jpg
PEAVEY POWER AMP CS3000
http://www.peavey.com/assets//images/ad ... 1050_4.jpg
PEAVEY POWER AMP CS 4800 8 Bucati
PEAVEY Signal Procesor VSX24 1 Bucata
RCF ART 322-A STAGE MONITORS 5 bucati
SOUNDCRAFT GB-4 32 ch. 1Bucati
DBX compressor 2 Bucati
TC ELECTRONICS M-one 1 Bucati
SHURE 7KIT DRUMSET MICROPHONES 1 Bucata
MICROPHONE STANDS K&M 10 Bucati
SHURE SM58 mic. 4Bucati
SHURE SM57 mic. 4Bucati
32/8 MULTICORE 1Bucati
TAMA STARCLASSIC DRUM SET 1 set
HARTKE SYSTEM BASS AMP+sp AMPEG 1 Bucata
MARSHALL GUITAR AMP 1 Bucata
SIGNAL CABLES 200
POWER CABLES 10
Lights
PAR 64 500w 24 bucati
MOVING HEAD 575 W SPOT 16 DMX CHANNEL 4 bucati
MOVING HEAD 575 W WASH 16 DMX CHANNEL 4 buati
GLP LIGHT OPERATOR CONTROLLER 1
STAIRVILLE BLINDER 2
MARTIN LIGHT JOKEY 1
SHOWTEC DIMMER 6CH 1
THEATER SPOT DTS 4
HARTING CABLES 20
POWER DISTRIBUTOR 63A 1
POWER DISTRIBUTOR 32A 2
POWER DISTRIBUTOR 16A 2
POWER BOX 16 A-6 SCHUKO 2
Tehnicieni scena
Inginer de sunet
Tehnician lumini
Scena
Poarta schela
6/8 sau 8/10
incarcare maxima acoperisi max 1200 kg
Inaltime 7 metri
Podium
inaltime 1.20 metri
2 scari stanga si dreapta
trasportul se face cu:
Iveco 7.5 t
iveco 3.5 t
Pentru oferta de pret contactati-ne la office@proaudiostore.ro
sau www.proaudiostore.ro/contact
0751863153
PRET DE CRIZA pentru PA cu tehnicieni ,inginer de sunet si luminist dar fara trasport 500 Euro.
Ultima oară modificat de Proaudiostore pe Mar Sep 01, 2009 9:16 pm, modificat 1 dată în total.
Izolatie fonica si tratament acustic
http://www.proaudiostore.ro
0767273950
Proaudiostore
UNREAD_POSTde Proaudiostore » Mar Sep 01, 2009 9:15 pm
Cautam si DJ care pot sustine un event house .Beatmatch ul trebuie sa fie la el acasa.In general se merge pe CDJ1000MK 3 si Xone 92.Dar pupitrul poate varia pa la CDJ 400 cu DJM 600 da r nu mai jos de CDJ 400.200 si 100 sunt fumate de mult si nu vreu sa chinuim DJ-ii.O sa anu t pe forum cand sunt eventuri si nu am DJ.
0767273950
Proaudiostore
Înapoi la Oferta servicii diverse
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 9 vizitatori
