Vand o pereche de casti Sennheiser HD 25 SP-2.
Sunt in stare tehnica si optica foarte buna.
Pot sa spun ca suna aproape perfect si foarte clar.
Pentru cine nu stie, acest model se recomanda la monitorizare,inregistrari in mediu exterior si pt dj.
Au un spl bun si izoleaza foarte bine urechea de zgomotele exterioare.
Le am din Anglia de la un amic.
Ele au suferit o mica modificare.
Fiecare casca avea pe firul care intra ea cate o mufa.
Una din mufe s-a intrerupt si au fost trecute ambele pe direct.
Features
Very lightweight and comfortable, even if used for long periods
High maximum sound pressure level
65 .nominal impedance for universal compatibility
Tough, detachable steel cable
Neodymium ferrous magnet systems and lightweight aluminium/copper voice
Technical Data and Specification of HD 25-SP II
Wearing style Headband
Color black
Frequency response (headphones) 30 - 16000 Hz
THD, total harmonic distortion <0,4 % dynamic, closed
Contact pressure ca. 3 N supraaural
Ear coupling supraaural
Jack plug 3,5/6,3 mm stereo
Cable length 3 m
Transducer principle dynamic, closed
Weight Without cable: 115 g
Nominal impedance 60 Ω
Load rating 200 mW stereo
Max. Sound pressure level (aktiv) 114 dB
Pret negociabil 320 Ron
Sau schimb cu hard extern de 1 TB usb 3.0
