Vand 2 topuri JBL PRX 715 si boxa bass JBL PRX 718 XLF
UNREAD_POSTde djstore » Mie Feb 10, 2016 6:55 pm
Se vand doua topuri JBL PRX 715 si boxa bass JBL PRX 718 XLF .
Specificatii tehnice JBL PRX 715:
- active multi purpose speaker 15" 1,5", 43 - 19.600 Hz, Class-D Crown-Amplifier with 1500 Watt bi-amp, 136 dB SPL max, internal DSP Controller, Dual pole mount, black housing, 90 x 50°, switchable EQ, 2 channel Mixer, 2x XLR/Jack Combi Input, Aux LR Input, XLR male Thru out, Neodym-HF Speaker, switchable GND/Lift, 9x M10 flying points, dimensions HxWxD 714 x 445 x 359 mm, 21,6 Kg;
Specificatii tehnice JBL PRX 718 XLF:
- JBL PRX 718 XLF, active Subwoofer, 18" reflex housing, 30 - 103 Hz, Class-D Crown-amplifier with 1500 Watt, 134 dB SPL max, internal DSP Controller, black housing, switchable Stereo HP filter, switchable Polarity, 2x XLR Input, XLR male Thru out, M20 stand adapter, dimensions HxWxD690 x 523 x 724 mm, 36,8 Kg;
Echipamentele sunt impecabile din punct de vedere estetic si tehnic , au fost achizitionate noi cu factura de la thomann - Germania in urma cu 2 ani.
Pret: 2000 Euro usor negociabil.
Telefon: 0745 939 116
djstore
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 35 vizitatori
