Vand Hercules DjControl AIR
UNREAD_POSTde GeoMDragos » Mar Iun 02, 2015 4:11 pm
Consola Dj destinata incepatorilor.
Se poate mapa pe traktor. Vine si cu softul original Djuced.
Consola arata ca noua, fara zgarieturi, defecte.
Toate functioneaza normal.
Placa audio integrata, intrare casti, iesire jack pt sistem.
Am la ea cd-ul original si cutia.
Pot trimite si in tara, prin fan curier (rezolv eu ca am contract cu ei).
NU DORESC SCHIMBURI. PRET 350 ron negociabil.
Tel: 0735185519
Caracteristici
1) 2-Deck DJ controller with pressure detection jog wheels, ideal for scratching
2) Innovative AIR control allows you to effect certain parameters without ever touching the controller
3) DJ Control Air converts the distance to your hand into a MIDI command, which can control volume level, effects, and more
4) 8 touchpads with progressive sensors that transmit a command and its velocity, to control loops, samples or effects
5) Multiple audio outputs, 1/8” stereo output for the mix and 1/4” stereo output for headphone monitoring
Includes a copy of DJUCED DJ software
GeoMDragos
